form buttons
August 29, 2008 2:26pm
  • #1 / Aug 29, 2008 2:26pm
    aran384
    Hi am wondering whether it is possible to add a ID attribute to the button that is generated by form_submit.
  • #2 / Aug 29, 2008 5:46pm
    Bramme
    RTFM…
    form_input()
    Lets you generate a standard text input field. You can minimally pass the field name and value in the first and second parameter:
    echo form_input(‘username’, ‘johndoe’);
    Or you can pass an associative array containing any data you wish your form to contain:
    $data = array(
              ‘name’      => ‘username’,
              ‘id’      => ‘username’,
              ‘value’    => ‘johndoe’,
              ‘maxlength’  => ‘100’,
              ‘size’      => ‘50’,
              ‘style’    => ‘width:50%’,
    echo form_input($data);
    // Would produce:
    <input type=“text” name=“username” id=“username” value=“johndoe” maxlength=“100” size=“50” style=“width:50%” />
    And then
    form_submit()
    Lets you generate a standard submit button. Simple example:
    echo form_submit(‘mysubmit’, ‘Submit Post!’);
    // Would produce:
    <input type=“submit” name=“mysubmit” value=“Submit Post!” />
    Similar to other functions, you can submit an associative array in the first parameter if you prefer to set your own attributes.
  • #3 / Aug 29, 2008 5:53pm
    aran384
    Firstly that is a very inappropriate reply.
    And secondly I did not notice this, you could of quite simply said you can use the array’s like the other variables instead of giving such a reply.
  • #4 / Aug 30, 2008 6:23am
    Bramme
    “Such a reply”? I handed you the solution, by quoting the user guide, what’s wrong with that?
    And okay, RTFM is an acronym with “fucking” it and that’s not a very nice word, but you could’ve bothered a bit more, you didn’t even post this in the right forum category…
  • #5 / Aug 30, 2008 7:16am
    Colin Williams
    Bramme: JATFQWOSA
    aran384: DBSAWNWPA
    everybody: RTFM twice, UTFM everyday
  • #6 / Aug 30, 2008 3:58pm
    Bramme
    Okay, I’m at a loss… What do those mean? :p
