Hi, I have a site running EE 1.6.3 (Commercial License). I created a new member group called admin, as I would like some people to be able to do certain things, but not everything a super-admin can do. Whenever a admin updates a post, the status gets reset to closed. I’ve tried everything I could think of.
1. Check the weblogs for their status group.
2. Set the default status to “open”.
3. Remove the drop-down for status from the CP.
4. Delete “closed” status from DB.
5. Set the publish to only be able to use “open” in the CP classes.
None of these solved the problem. Does anyone have any suggestions on what to do, right now I have to edit multiple entries and mark them as open for the status to update. Is there a way to make even closed items show up on the site?
