Nice to see we are discussing the same !
You can figure it out by looking at the backend code, but that’s not particularly user friendly.
I agree…
I think this would be a case for a feature request.
Then today wille my FR-day, with a third one.
More seriously:
One short term option is to try searching the files via a file manager/search utility on your local machine- that might be a quick way to do it in the meantime.
Yes, that is what I did. And my concern is that I did not found anything.
Since first message I search in a dump of the database. And i found: that is in the exp_member_groups table, original parameter from installation.
As a provisional conclusion:
1/ Many people already faced the same: to find in which tables there are some labels to translate. Is there any page in the KB where it is documented ? (I am going to search).
If not how to share experience from members who worked on the pb as I am Going to do ?
2/ My first question about the map is still open and I think it would be helpful for make localization easier.
Do you share my view ?
