so tell me if i wanted to create a website that housed user hardware compatibility based on a single operating system, would ci be the way to go? I am new to this but learn very well..
June 23, 2007 10:31pm
Subscribe [3]#1 / Jun 23, 2007 10:31pm
#2 / Jun 24, 2007 12:31am
Hello
Could you provide more details?
#3 / Jun 24, 2007 6:59am
CI is a framework, so you should be able to build anything upon it, it depends on the approach tat you use.
#4 / Jun 25, 2007 9:34am
Hello
well for instance a user would register, upon registration or in his/her profile they can update their hardware list and select from a drop down list how that specific hardware is working for their operating system. Together this information is gathered to generate stats for others - say if you want to know if your ati x850 card will work with ubuntu edgy, you could do a search for that and see how many users have this card working 100% with no problems and so on.. kinda hard to put in words whats in my head
#5 / Jun 25, 2007 5:23pm
Yes is completely feasible with CI.
Start with the User Guide, then watching the videos and tutorials, and you’ll have a base to begin your project.
#6 / Jun 30, 2007 2:27pm
Should be possible! 😊
#7 / Dec 01, 2011 1:20pm
Yeah you should totally be able to make that work. Good luck
