Hey, I have had a lot of problems with moving to new server and later upgrading my EE. Just a short background story. In order to get EE working on the new server I had to convert my database and all tables to UTF-8 (still some missing characters, but those I’ll replace manually). I’m worried that anything below could have to do with this.
These are the problems I have had after updating from 2.1.0 to 2.5.3.
1. After installation was finished I got the following message:
“An Error Was Encountered
Unable to load the requested language file: language/english/ip_to_nation_lang.php”
I don’t use IP to Nation, so I just went to the CP and uninstalled it (don’t know if I should be worried something more has gone wrong?)
2. When I go to the start-page of my CP I had the following message:
“Your ExpressionEngine installation’s version (2.5.2) is not consistent with the reported version (2.5.3). Please update your installation of ExpressionEngine again.”
However, in my footer it says 2.5.3. I assume this could have to do with no (1.). I really don’t feel to reinstall again, as I have done that 3 times (every time take a lot of time) and the last 2 times I got that language file error that nobody seem to have been able to fix. If I go to the config file and change the “app number” from 252 to 253, the error message goes away. Should I worry about this. Or could I let it go?
3. I had a weird PHP error when I tried to edit or create entries that involved the “File field”. But after synchronizing all my images in file manager the PHP error went away. However, now when I go to edit an entry containing a file in the file field, the thumbnail of the image is missing (instead of showing tumbnail + file name, it now shows file name + file name). It doesn’t seem to have any technical effect on the webpage as the images and files show as it should.
Other then these issues, everything seem to be working as it should.
Johan
