Submitting entry does not save & redirects back to publish page
July 19, 2012 4:44pm
Subscribe [5]
  • #1 / Jul 19, 2012 4:44pm
    Submitting new entries does not save, then redirects back to publish page. Occurs for ‘admin’ and also non-admin users. Where should I start to diagnose this?
    Update: Created brand new channel to test. Same issue.
    * Upgraded to EE 2.5.2
  • #2 / Jul 19, 2012 5:28pm
    Kevin Smith
    Hi P. Colin Manikoth,
    Are there any errors in the publish form? That’s usually the cause of something like this. Be sure to check all the tabs and look for the error message at the top of the screen. Let me know what you find!
  • #3 / Jul 19, 2012 6:04pm
    * Fix: Disabling all required fields allows for new entries to be created
    * No errors on any forms/tabs
    For now, removing required fields is the workaround.
  • #4 / Jul 20, 2012 10:57am
    Kevin Smith
    Hmm… so it sounds like one of the required fields was holding up the submission. Did you figure out which field was tripping it?
  • #5 / Jul 27, 2012 12:29pm
    Triad
    really weird - we having the same issue.
    Brand new install of a website… all of a sudden, on any channel when we hit ‘Submit’ at the bottom… it just reloads and doesn’t save…
    same with when Edit any..
    Latest EE install of 2.5.2
  • #6 / Jul 27, 2012 12:30pm
    Triad
    Looking through each Tab once we click ‘Submit’ - on the Pages one we get “Invalid Page URI” - never had this before though!?
  • #7 / Jul 27, 2012 12:32pm
    Triad
    Disabling ‘Pages’ module makes everything work… Strange ?!
  • #8 / Jul 27, 2012 6:58pm
    Kevin Smith
    Triad,
    Did you happen to see what the Pages URI that was declared invalid was?
  • #9 / Jul 30, 2012 3:55am
    Triad
    Triad,
    In the URL box, it has
    /example/pages/uri/
  • #10 / Jul 31, 2012 10:58am
    Shane Eckert
    Hello Triad,
    I believe what Kevin is asking about is not the content of the box, but in the URI what was there that threw the message Invalid Page URI when you hit submit?
    Are you using any Add-Ons?
    Are you using a .htaccess file? If so, can you show the contents of that file?
    Thank you!
  • #11 / Aug 20, 2012 1:41pm
    It was an overlooked required field from a depreciated addon. Check for any required fields.
  • #12 / Aug 20, 2012 3:55pm
    Shane Eckert
    Hey Triad,
    How are things going?
  • #13 / Oct 26, 2012 11:59am
    louisk
    I am having the exact same issue.
    EE 2.5.3
  • #14 / Oct 29, 2012 2:52pm
    Kevin Smith
    Hi louisk,
    Could you give me some more to go on? Are these new entries being created or existing entries being edited? When you go back to the publish page, is there an error displayed anywhere? Does this happen with all channels or only some? Is there a common fieldtype in all the channels that behave this way?
  • #15 / Oct 30, 2012 9:40am
    louisk
    Hi Kevin,
    I tried to PM you via another topic on a similar/the same issue.
    It not only happens in channels, but anywhere. Some times it does happen, other times is doesn’t.
    It can happen when saving channel fiels.
    I was hoping you could provide some more details about the exact security rules you referred to (http://ellislab.com/forums/viewthread/201987/).
