Hello
Could someone help me with the following.
I have categories with sub categories and I would like the following
1 url output (limit=“1”)
site/{category_url_title}/{sub_category_url_title}
How could I do this?
With kind regards,
Martijn
May 14, 2012 5:48am
Subscribe [2]#1 / May 14, 2012 5:48am
Hello
With kind regards,
Martijn
#2 / May 14, 2012 10:34am
Sorry, what are you trying to do?
If it’s achieve a URL with both category and subcategory segments then EE doesn’t do that natively. I’d suggest looking at Low’s Seg2Cat addon.
#3 / May 14, 2012 10:37am
Thanks Boyink!
Just solved it my self.
One other problem.
How do I display entries belonging to a sub-category?
domain.com/site/country/state
country = category
state = sub category
I submit my entries to a sub category.
How could I show entries belonging to a sub category.
regards,
Martijn
#4 / May 14, 2012 10:43am
From a entry display perspective, unless you are using add-ons, to EE a subcategory is the same as a category. EE knows which entries to display based on seeing a correctly-formatted URL.
I’d suggest reviewing this tutorial:
http://www.train-ee.com/courseware/free-tutorials/comments/working-with-categories/
However if you’ve created non-standard URL’s it isn’t going to work - this is where Lows Seg2Cat comes in.
#5 / May 14, 2012 10:46am
Nice.
Category and sub category are using the standard URLs (As far I can tell)
Example:
Category “The Netherlands” url = the_netherlands
same for sub category.
I will look into your suggestions.
Thanks 😊
#6 / May 14, 2012 12:57pm
Seg2Cat did the trick.
Thanks Boyink! 😊
#7 / May 15, 2012 10:34am
Hi Martijn,
It looks like Mike and Seg2Cat have solved your issues?
