I’m using the Field Display Order field to re-oragnize the field arrangement in my channels but it doesn’t seem to be working. Not matter what numbers I enter into the Field Display Order channels the fields are always sorted by Field ID. I know that you can use the Publish Layouts to re-arrange the fields, but I’m wondering why the Field Display Order doesn’t seem to be working? I’m running EE 2.4.0 Build 20120123. Thanks.
