getting same issue as previously mentioned
Update failing on DB “Unknown Column wm_x_offset in exp_file_watermarks”
This error seems to be pretty specific. can the column be updated manually (added) in the DB?
btw it might be nice to a have a db “integrity checker” that can be used before upgrade to verify db has all fields and columns required.
