Fatal Error When Commenting... but it still posts
January 25, 2012 10:18pm
  • #1 / Jan 25, 2012 10:18pm
    lealea
    Fatal error: Call to undefined method CI_Model::CI_Model() in /expressionengine/modules/comment/models/comment_model.php on line 29
    I get the following error when I press Submit when commenting in the latest 2.4.0. I use just the default template code with some styling added, so nothing crazy.
    However, when I go back to the entry page, I notice the comment has actually posted.
    Help?
  • #2 / Jan 26, 2012 8:52pm
    Dan Decker
    Hey Lea,
    I just did a test to see if I could replicate and I had no errors at all. My 2.4 was a fresh install though. Are you seeing this after an update? Another thing that seems odd is the path in the error. There is no model directory under /system/expressionengine/modules/comment/ The file the error reference should be located at /system/expressionengine/models/comment_model.php Can you look in those two places and let me know what you find?
  • #3 / Jan 26, 2012 8:58pm
    lealea
    This was an upgrade from 2.1 to 2.4. Checking the /modules/ folder there WAS (strangely) a comment_model.php file there. I deleted it and now no more error. Things work!
  • #4 / Jan 26, 2012 9:00pm
    Dan Decker
    Wow, I kinda stumbled into that one! 😉
    Awesome! Is there anything else I can assist you with?
