Exclusions from RSS templates
December 05, 2011 5:51pm
  • #1 / Dec 05, 2011 5:51pm
    sartaingerous
    Hello,
    I have three RSS templates on my EE site, one for the index, one for single column pages and one for two-column pages. I have the RSS feeding into SearchSpring so that the entire site is searchable. The problem is that I have some testing pages and thank you pages that I do not need searchable…
    Is there a way to exclude a list of pages or something so they are not fed into RSS, without a 3rd party add-on or module?
  • #2 / Dec 06, 2011 12:08pm
    sartaingerous
    Word? Nothing?
  • #3 / Dec 06, 2011 2:10pm
    Rob Allen
    There are many ways to do this…
    Your RSS feed content is generated by channel entry tags so you many options, here’s one:
    Use a custom field with a simple Yes/No option
    - create a select or radio field, eg called rss_exclude, set the field value as required for the entry, then in your feed template use the search parameter to exclude:
    {exp:channel:entries channel="channel" search:rss_exclude="no"}
    You could also use a checkbox, custom status, even by excluding a category from the channel entries tag.
  • #4 / Dec 06, 2011 5:29pm
    sartaingerous
    Hot damn! Worked like a charm.
  • #5 / Dec 07, 2011 2:14pm
    Rob Allen
    Glad you got it sorted. Adding Yes/No options like that can have many uses 😊
