John,
I was able to reset the layout and the errors are gone. Thanks for your assistance you can close this issue.
How do you reset the layout? I am having the same problem.
October 17, 2011 12:48am
Subscribe [1]#1 / Oct 17, 2011 12:48am
John,
#2 / Oct 17, 2011 8:51am
Hi..
See the attached screen shot. You’ll need to make sure your toolbar is visible.
#3 / Oct 17, 2011 9:40am
I found it. Will reset layout delete the entry? Thanks Sue.
#4 / Oct 17, 2011 9:52am
What I do is start to create a new entry, so that way you don’t need to worry about it.. it’s the layout that should be removed, not an individual entry.
#5 / Oct 17, 2011 9:55am
Worked like a champ. I created a new entry ... then selected reset layout. Thank you
#6 / Oct 17, 2011 10:02am
Yay! Feel free to start a new thread if you have any more questions.
