Entries dated in the future are not showing up after the entry date and time passes. Setting the date back by one day, and then putting it back to the initial date fixes this.
Here are the specific settings of the entry:
- Date > Entry Date: “2011-08-24 07:30 AM”
- Options > Status: Open
- Options > DST Active on Date of Entry, checked
Here are my localization settings:
- Server Time Zone: Pacific (confirmed by host)
- Server Offset: blank
- Default Time Formatting: US
- Daylight Saving Time: Yes
- Honor Daylight Saving Time setting associated with each channel entry: Yes
So for the above example, the entry was not showing at 7:45 AM this morning. I went into the entry and just changed the date to “2011-08-23 07:30 AM”—one day back—and then the entry showed up.
Then I went back into the entry and changed it back to “2011-08-24 07:30 AM”, what it was initially set to, and the entry remained showing.
I am not sure if this is expected behavior, but the part that seems off is the entry would show not show up, and then show up (after setting the date backwards and forwards), with the same entry date in both cases.
Any ideas? Is this possibly a bug that gets fixed in a more current version? This install is 2.1.0, build 20100810.
