Dear EE —
I’m trying to upgrade to 213 (from a 171 installation). I’ve tried every way I could understand to achieve this. Among many threads. I’ve gave a shot to this one as well (even though not directly related) — http://ellislab.com/forums/viewthread/186735/.
I keep getting the same error over and over again.
Error Number: 1075
Incorrect table definition; there can be only one auto column and it must be defined as a key
ALTER TABLE `exp_weblog_data` DROP KEY `entry_id`
Filename: updates/ud_200.php
Line Number: 1382
Working on a local server using MAMP.
Among other things, I’ve done:
- Increased memory limit on php.ini
- Repaired/Optimized tables
- Manually cleared up tables (security hashes, referrers)
I’ve even tried installing a fresh EE213 and using DataGrab to set-up entries from scratch, however that didn’t do the trick either.
I’m running on my last fuse and I’m hoping you guys can run your magic dust through this one as well : ) — I’m sure its an easy one.
Cheers.
— Valon.
