URL base path/site path - how to change base/root URL?
March 19, 2011 12:03am
  • #1 / Mar 19, 2011 12:03am
    dzaun
    I have installed EE on a dev server with a fake domain that I have no intention of putting online.  Since it is not online, I need to access the CP this way:
    http://65.33.44.55/$sitepreview/devsite.com/system/index.php?S=0&D=cp&C=homepage
    The problem is that the CSS and images are being referenced at http://devsite.com.  What do I need to change so that the everything is referenced relative to http://65.33.44.55/$sitepreview/devsite.com.
    Thanks for any help!
  • #2 / Mar 21, 2011 3:30am
    dzaun,
    Are you referring to the control panel or the frontend?
    If the control panel then just goto your General Configuration and update your Site and Theme URLs and paths
  • #3 / Mar 21, 2011 12:16pm
    dzaun
    Thanks John.  I tried to access General Configuration in the Control Panel, but the page doesn’t load, I get an “object expected” error in IE.  Actually, all of the functions error out.  Does the General Configuration update the config.php file?  If so, what exactly should be changed?
  • #4 / Mar 21, 2011 1:24pm
    dzaun
    John,
    This was resolved using the General Configuration function.  I was getting errors, but the prompts were still displayed at the bottom and I was able to update the Site and Theme URLs and after a refresh it looks and appears to act like it should again.
    I’m still curious where the Theme URL and path are stored because I don’t see them in my config.php.
    Thanks for your help!
  • #5 / Mar 22, 2011 6:00am
    dzaun,
    They are stored in the sites preferences in the db but you can also override them in the config.php file if needs be
  • #6 / Mar 22, 2011 2:12pm
    dzaun
    Excellent, thanks for the information!
  • #7 / Mar 23, 2011 8:05am
    No problems. Feel free to start a new thread if you have any more questions
