Ok, here I go again, with a complete new thread.
I managed (after initial installation problems ... see my other post on my recommendation on how to best install on a live server) to install EE on a live server (within password protected directory since this setup is only used for learning and testing)
I also installed the “Agyle” sample template
then I installed MSM
then I installed the Forum (important here again, upload all folders in “BINARY” mode otherwise you may get some missing bytes warnings)
Now I need really help because I try to do everything right from the beginning and before I even can start, I am confused already. Following the “forum-setup-documentation” for a “first time” setup I can’t even start because things are no in place as the documentation requests!
kindly see the attachment “1.time_forum_setup.png”] - it clearly tells you what to do first! The only thing is ... I can’t find anything that I should find, according to the documentation. All I have is what you can see in the second screenshot “EditForumBoards.png” ... where is the Forum Management tab? Where is the “General Preference” link (for the forum preferences)? Am I that blind? Or do I have the wrong documentation (that’s the one recommended to me for download after I purchased EE 2.1.1
