I have a couple of sites running perfectly on v2.0.2pb01 with several third-party plugins in use.
Installing 2.1 is extra work, and at least has some potential to break compatibility with plugins, etc. Can I safely continue running the beta? Is there any known security risks or other downsides?
It seems like the upgrade process should be a lot easier (nothing more than a couple of clicks, or similar). The current upgrade process is essentially “re-install EE and get everything working again”. Disappointing, to say the least. Will this change in the future?
Thanks for any input or advice.
