Don’t receive confirmation emails using the mailing list module
October 18, 2010 7:23pm
  • #1 / Oct 18, 2010 7:23pm
    Zlate
    As the title says, I installed the mailing list module and used the tags provided in the users manual.
    My code is as follows:
    {exp:mailinglist:form list="newsletter-periodical"}
    <input type="text" name="email" value="{email}" class="input" />
    <input type="submit" name="send" value="Испрати" class="button" />
    {/exp:mailinglist:form}
    It basically works, as per the successful messages I receive upon submitting. Also when I submit with the same email again it recognizes it telling me that a confirmation email is already sent, but it isn’t.
    It’s so damn simple that I can’t imagine I’m making any errors :roll:
  • #2 / Oct 18, 2010 9:52pm
    Greg Aker
    you on 1.x or 2.x, braveheart?
  • #3 / Oct 19, 2010 8:50am
    Zlate
    I’m on v2.1.0 Build 20100810.
  • #4 / Oct 19, 2010 3:59pm
    Greg Aker
    okay cool.  I’m moving you up to the tech support forums.  😊
    To confirm, you have checked your spam folders, and have not found them there, right?  You have problems with other EE-generated emails?
  • #5 / Oct 19, 2010 4:32pm
    Zlate
    Yes I checked my spam folder and nothing was there. I haven’t tried other EE-generated email so far.
  • #6 / Oct 19, 2010 7:45pm
    Try sending an email to yourself from the Communicate tab. See what happens then.
  • #7 / Oct 19, 2010 9:17pm
    Zlate
    I just sent it and it worked instantly.
  • #8 / Oct 20, 2010 10:03am
    That’s progress! OK, did you set Webmaster or site name for auto-generated emails to anything?
    CP Home > Email Configuration
  • #9 / Oct 20, 2010 12:31pm
    Zlate
    Nop, I haven’t touched that field, it’s blank.
  • #10 / Oct 20, 2010 3:48pm
    Zlate
    Just to be sure, I developed a simple stand-alone form to see if it will work… and it works perfectly! The data from the form fields are sent to my email without a problem.
  • #11 / Oct 21, 2010 3:19am
    braveheart,
    In your Mailing List preferences have you turned on Enable recipient list for notification of new mailing list sign-ups and added your email to Email Address of Notification Recipient(s) ?
  • #12 / Oct 21, 2010 8:58am
    Zlate
    Nop, it was set to “No”. In fact I haven’t even touched those fields. I still can’t figure out why I don’t receive confirmation emails. I’ll try to find and see if the emails are at least stored in the database, if that helps.
  • #13 / Oct 21, 2010 9:09am
    braveheart, if you don’t turn the setting On, and set a valid email address to be contacted, that’s why you aren’t getting the emails.
  • #14 / Oct 21, 2010 9:41am
    Zlate
    Ok I set the “Enable recipient list for notification of new mailing list sign-ups” to “Yes” and added my email address to “Email Address of Notification Recipient(s)” field, but still nothing changed.
  • #15 / Oct 22, 2010 3:25am
    braveheart,
    Please fill in the Webmaster or site name for auto-generated emails preference.
    Have you got a link to your signup form so I can add my own email to test for you?
