Entry & Expired Dates decreases by an hour when posted/edited
September 30, 2010 10:20am
Subscribe [10]
  • #1 / Sep 30, 2010 10:20am
    jstewart
    Build: 20100810
    Whenever I post or edit a channel entry that has a entry/expiration date after 31st October when DST ends (UK), the time within the date is automatically decreased by 1 hour.
    E.g. I post a date of 2010-11-06 12:00 it will save as 2010-11-06 11:00
    I have the following settings;
    TimeZone: UTC
    Daylight Saving Time: No
    Honor the Daylight Saving Time setting associated with each channel entry? No
    User localisation settings > Daylight Saving Time: No
    I’m using expression engine to run an events calendar, so the time of the event is really important.
    Is there anything I can do to make posts ignore the DST settings and just keep the time that is entered into the post?
    Thanks for the help in advance.
    John
  • #2 / Sep 30, 2010 10:53am
    rjsteck
    I am having the same issue. I was going crazy and thought it was my system.
    I have updated the system/expresionengine/fieldtypes/ft.date.php file so the save function looks like this
    function save($data)
            if ($data != 0 && date("I",$data) == 0){
                $data = mktime(date("H",$data)+1,date("i",$data),date("s",$data),date("n",$data),date("j",$data),date("Y",$data));
            return $data;
    It appears to be working.
    I need to test what happens after the system date is when daylight savings is off, but this will hold you over for a month or so.
    edit… code was bad :(
  • #3 / Sep 30, 2010 11:58pm
    Brandon Jones
    Hi jstewart,
    In Admin > Localization Preferences, what is set for Honor the Daylight Saving Time setting associated with each channel entry? Have you tried toggling this to see if it helps?
  • #4 / Oct 01, 2010 6:02am
    jstewart
    Hi Brandon,
    ‘Honor the Daylight Saving Time setting associated with each channel entry?’ Is set to ‘No’ toggling it to ‘Yes’ doesn’t change anything. Dates posted after DST ends on the 31st of October decrease by one hour each time they are added or edited.
    John
  • #5 / Oct 01, 2010 1:48pm
    rjsteck
    I have tried every combo possible. I am guessing that since Daylight saving toggles have no effect then that is the problem. I believe the error lies in
    $this->EE->localize->some_date_function_that_is_doing_dst_changes_wrong();
    If you would like to tell me what file this code resides in I would be more than willing to try a “fix” - and not a hack like my code above.
  • #6 / Oct 02, 2010 9:53am
    Jan_Huygens
    hah - I’m having this problem too.  Glad its not just me!
  • #7 / Oct 02, 2010 6:01pm
    rjsteck
    Ok, well I think I found the issue and I would like feedback. Below are lines 470 through 487 of system\expressionengine\libraries\Localize.php It appears that this code is what is messing things up and it appears that this is “intentional” as the comments say exactly what happens yet we don’t want it to happen.
    // Offset the time by one hour if the user is submitting a date
            // in the future or past so that it is no longer in the same
            // Daylight saving time.
            if (date("I", $this->now))
                if ( ! date("I", $time))
                    $time -= 3600;
            else
                if (date("I", $time))
                    $time += 3600;
    I changed the file to look like this and all it well (be sure to take my above hack out of your code)
                    $time -= 3600;
            else
                    $time += 3600;
  • #8 / Oct 04, 2010 2:44am
    Looks like you are all running into the date bug which was reported and confirmed here
    There are some case scenarios from users within the comments of that report. It looks like your particular case above matches a few. Can you confirm this?
  • #9 / Oct 04, 2010 12:52pm
    rjsteck
    That does not appear to be the same bug.
  • #10 / Oct 04, 2010 5:01pm
    Thank you for your feedback, rjsteck. The issues surrounding time/date and DST are being revisited for the bugfix John pointed to.
  • #11 / Oct 11, 2010 5:30pm
    rjsteck
    Thank you, I will work through that thread to get the issue resolved.
  • #12 / Oct 12, 2010 11:27am
    Just to add to this thread.. we’re going to be thoroughly testing date/time issues before the next build/version is released. We appreciate your patience.
  • #13 / Oct 20, 2010 4:10pm
    eguystephens
    Has this been fixed yet?
  • #14 / Oct 20, 2010 4:27pm
    No, as this is a somewhat complex issue. You can read more about it here.
  • #15 / Nov 02, 2010 3:38pm
    Joe Michaud
    Is there a work-around to the “one hour rollback” problem for new sites?  I have a site launch hanging on this issue.
