I am having problems uploading files using the file manager of the Control Panel.
The problem it displays is:
PHP Error was encountered
Severity: Warning
Message: require_once(/www/eh12857/public_html/system/expressionengine/config/CI_mimes.php) [function.require-once]: failed to open stream: No such file or directory
Filename: helpers/file_helper.php
The problem is that I do not have the file CI_mimes.php which is called from file_helper.php. According to the logs, CI_mimes.php was taken out on EE 2.1. I lost the file when I was upgrading to EE 2.1 from the Beta version. During the upgrading process, I had a problem so i decided to cancel it. Everything works fine on the site and the CP, except for file manager.
How can I fix this problem?
