I just installed MSM, after that If I turn on MSM in admin > System Preferences, I cannot able to login to control panel. If I turn off I can able to login. Please help me..l This is really urgent.
Nallasivan
March 19, 2010 3:33am
Subscribe [4]#1 / Mar 19, 2010 3:33am
Nallasivan
#2 / Mar 19, 2010 3:54am
Nallasivan
You can find this in the footer of your control panel.
When you set the Enable Multiple Site Manager to yes in Admin › System Preferences › General Configuration what happens?
Does it log you out back to the login page?
Are you able to goto Edit Sites under the new Sites tab?
#3 / Mar 19, 2010 3:59am
Hi John,
My version is ExpressionEngine 1.6.8 Build: 20090723.
When I set the Enable Multiple Site Manager to yes in Admin › System Preferences › General Configuration ,
It doesnot log me out. But when I close the browser and open the controlpanel again I couldnot able to login again.
I can see the new tab called sites. I also created a new site. But when I select the newly created site under the sites tab, it is loading the default site.
Please help me. Today I need to resolve this issue since I have a urgent commitment tonight.
Nallasivan
#4 / Mar 19, 2010 4:07am
Hi John,
For your information.
Actually I was using the core free version build 20090723, but after that we bought licensed commercial version with build id 20100121. Today I upgraded to the licensed version. After that I installed MSM.
In the upgradation I just replaced the folder mentioned in the upgrading tutorial. is that a problem. do i need to replace any other thing.
#5 / Mar 19, 2010 4:24am
You replaced all the folders mentioned here?
http://expressionengine.com/docs/installation/update_from_core.html
Does it refresh the page when you enter your login details again?
When you created your new site did you create a blank one or duplicate your default site?
Have you updated your settings in Admin -> General Configuration for the second site?
#6 / Mar 19, 2010 4:30am
Yes I replaced all the folders given in the document below.
I didnt do anything from the following document.
http://expressionengine.com/docs/installation/update.html
Yes it refresh the page after I enter the login details. but it didnt tell any messages. But if I gave any invalid username it is error out invalid user message. But when I give a valid username it just refresh and it wont go to the control panel and it is still in the login page.
I created a blank new site.
I cannot go to second site’s admin area. If i select the second site, it is still in the default first site. I cannot go to second site.
#7 / Mar 19, 2010 11:37am
So, just to confirm, you are on the latest version and build of both EE and the MSM? You followed the MSM installation instructions to the letter? Are you using any extensions?
#8 / Mar 22, 2010 2:36am
I followed all the steps for installing MSM. But still not able to login to the system when I turn on MSM in admin. When I switched off I can able to login.
Please help me.
#9 / Mar 22, 2010 2:41am
Hi
I was using core version with the build id 20090723 and last week I upgraded to ought licensed commercial version with build id 20100121. is that causing any issues.
Could you please provide me what extra step i need to do to upgrade.
#10 / Mar 22, 2010 9:01am
Nallasivan, how is your second site structured compared to your first site? Can you post what’s in your path.php file for the second site here?
#11 / Mar 22, 2010 9:15am
Hi Sue,
After installed MSM, i turned on MSM in Admin › System Preferences › General Configuration. After that I created a blank site called Test2. It is showing under Sites tab. but when I select the site “Test2”, it is defaulting to first site(i.e, default site.). I cannot do anything with Test2 since the breadcrumb is always showing SITE 1› even I select second site.
so I didnt put any path.php for second site, since I cannot able to change preferences for second site.
#12 / Mar 22, 2010 9:22am
Hmmm… have you tried deleting all your cookies and trying again? Or even with a different browser?
#13 / Mar 22, 2010 9:24am
Hi Sue,
I deleted all the cookies and tried. Even I tried using another machine. still it is not working.
Please help me.
#14 / Mar 22, 2010 9:34am
Nallasivan, please check your email account in a few minutes.
#15 / Mar 22, 2010 9:51am
Hi Sue,
I just sent the information. Please help me to resolve this issue as soon as possible.
Nallasivan
