[string manip Q] splitting string on 2nd space
January 10, 2010 12:26am
  • #1 / Jan 10, 2010 12:26am
    brianw1975
    Ok guys and gals i’ve been suffering code-block for the past couple of hours on this thing.
    I’m trying to generate some graphics via php based on fields in a database (there are roughly 1500 pictures that need to be created - so not doing them in Photoshop)
    Anyhoo…
    I’ve got a string “10¢ OFF Regular Price”
    How can I split that at the second space?  so that i get
    $str[1] = "10¢ OFF";
    $str[2] = "Regular Price";
    Like I said, been blocked for hours on this stupid but of junk, hoping someone can help me out.
    TIA.
  • #2 / Jan 10, 2010 3:25am
    brianw1975
    ah, yes, that would be a way.. however, as I said I have 1500 records that need to be parsed.  So, while yeah, that is a solution I was hoping for a suggestion that was a bit more robust, but… I may just have to use a hammer to nail and do a switch statement based on the size of the array generated from the explode and then concatenate those results… I could also customize it based on the length of the words as well…
    Thanks for the suggestion.
    Here are some other examples.
    ex:
    Beef
    Beef Stew
    Excellent For Broiling
    Hamburger from Ground Chuck
    Fully Cooked - Ready to eat
    Compre 1 y Gratis 1
    Reduced! use today or freeze
  • #3 / Jan 10, 2010 3:29am
    Dyllon
    Use explode(), then re-assemble as needed:
    <?php
    $foo = "Hello world. It's a beautiful day.";
    $bar = explode(" ",$str));
    echo $bar[0] . $bar[1];
    Untested.
    Use the limit parameter of explode to make it easier to re-assemble.
    $str = "10¢ OFF Regular Price";
    $arr = explode(' ', $str, 3);
    $arr[1] = $arr[0] . ' ' . $arr[1];
    array_shift($arr);
    print_r($arr);
    Result:
    Array
        [0] => 10¢ OFF
        [1] => Regular Price
  • #4 / Jan 10, 2010 4:06am
    Colin Williams
    You could use regex assertions to say, “find first space preceded by a space” but I’m not sure it would be any more or less efficient than what’s been suggested so far.
