Can’t get a new moblog to accept inbound emails.
I notice this thread: http://ellislab.com/forums/viewthread/101750/ suggests that the destination email must be associated with the domain. Is this true?
ExpressionEngine 1.6.7 - 20090211
August 01, 2009 6:45pm
Subscribe [2]#1 / Aug 01, 2009 6:45pm
#2 / Aug 01, 2009 7:08pm
It can be, depending on the hosting setup. Are you using gmail or a similar email service? Can you setup an email coming from the domain and give that a try?
-greg
#3 / Aug 01, 2009 7:24pm
the domain is on enginehosting. the destination address is on another enginehosting domain. i’ll have them set up a dummy i can use.
#4 / Aug 01, 2009 8:36pm
okay, also double check your pop settings & let’s see if that works.
-greg
#5 / Aug 01, 2009 9:59pm
Ehh… Tried that. Direct cut-paste from the email client where I can see the inbound posts that aren’t being accepted.
#6 / Aug 02, 2009 1:58pm
Can you send emails through the communicate module? Please go to: Admin -> System Preferences -> Email Configuration and turn email debugging to ‘on’ and give that a try.
-greg
#7 / Aug 02, 2009 2:59pm
yes, i can send emails through the communicate module.
the only debug msg i get is “your msg has been successfully sent using mail”
#8 / Aug 02, 2009 4:30pm
okay. Do you have an email that’s not associated with that domain you can try? Gmail can be tricky so something else would be good.
-greg
#9 / Aug 02, 2009 4:44pm
yeah, that’s where i started (non-gmail), but no good.
#10 / Aug 03, 2009 1:42am
mmcclung,
What actually happens when you send the email. Do you get the error in the CP or do you get a returned email in your client?
What Email settings are you using in the Moblog module, POP3?
Do you have a Subject Prefix set?
Is Authorization Required in Email set to yes or no?
Are you using the Valid ‘From’ Emails for Moblog feature?
