Moderator’s note: Moved to Tech Support.
Hi
I’ve done a brand new install of EE 1.6.8 on a Windows server and then installed the forum. All I get when I go to the forum is the ‘Unable to locate the following forum theme file’ error. I’ve checked all the forum posts about this issue and have tried the fixes mentioned in those posts without any luck. I’ve downloaded the files again and uploaded to the server with various FTP apps in various formats. The files are there in the correct folder (/themes/forum_themes/default/theme_index.php) and I can get directly to them via a browser. Permissions are correct but its tricky with a Windows server on shared hosting but I guess they must be ok as everything else in the site is working fine. I’ve checked paths and I think they’re all correct.
The page in question is here…http://www.themca.org.uk/index2.php?/forums/
“URL Segment Support” is not available on the server so force query strings is set to yes.
And it happens to all of the themes that come with the forums, its not specific to any one of them so i think it must be a bad path somewhere but I just can’t figure it out.
Any help would be greatly appreciated!
Paul
