Can't login using session ids
June 12, 2009 11:37am
  • #1 / Jun 12, 2009 11:37am
    magder
    I have a simple login form here.
    meetings.ou.org/bbest
    I need to NOT allow multiple logins with the same username.
    When I set sessions to session ids only in the control panel and the site I can’t login to the site but can login to the CP.
    When the form is submitted I get to the ee page that says “you are now logged in - click here if not automatically redirected”
    I’m redirected to the page specified in the return parameter
    But I’m not logged in.
    I can login with cookies and session ids but it is still possible for multiple logins on the same account.
    I’ve checked the control panel log and there is no record of logging in for that user.
    The user I’m testing happens to be a super admin but it won’t work with any member group I’ve setup.
    [deleted]
    I’m running the latest build of 1.6.7
    Extensions are disabled
    testing in ff and IE7
  • #2 / Jun 12, 2009 11:46am
    Try from some other computer, or even network. I suspect it might be a local issue, perhaps a firewall or something like that, especially given that cookies only work.
  • #3 / Jun 12, 2009 12:20pm
    magder
    I’ve tried another network and computer.
    The same problem.
    Also, session ID only works for the control panel but not for the front of the site.
    Were you able to login with the credentials In the post?
  • #4 / Jun 12, 2009 2:23pm
    Gary, the login information was removed from this post.
    Also, it looks like that template is in flux, I don’t see any sort of login info, and I see {radio_footer} at the bottom of the page…
  • #5 / Jun 12, 2009 2:39pm
    magder
    It’s a test page and the login form works for cookies and session id and cookies.
    Just not for session ID.
    Are you saying you don’t see the login form?
  • #6 / Jun 12, 2009 2:41pm
    That’s what I’m saying.
  • #7 / Jun 12, 2009 2:49pm
    magder
    Sue, my apologies!!!
    http://meetings.ou.org/bbtest
    I left out the “t”.
  • #8 / Jun 12, 2009 2:57pm
    Gary, are you using strictly EE, or are you using the Solspace User module?
  • #9 / Jun 12, 2009 3:39pm
    magder
    EE only.
    Its a separate instance of EE which we just setup yesterday.  We needed it to deal with this multiple users logging into one account.
    Could it have anything to do with the domain?
  • #10 / Jun 12, 2009 3:44pm
    Possibly.
    So are you certain that you need a different instance?
    Do you have your cookie domain set on the primary site?
  • #11 / Jun 12, 2009 3:47pm
    Gary, let’s back this up a bit.
    What are your actual goals?
    To prevent multiple logins? Are you using the MSM?
    Which version/build of ExpressionEngine are you using? You can find that out at the bottom of any control panel page.
    The current version is 1.6.7 and the build is 20090515.
  • #12 / Jun 12, 2009 3:52pm
    magder
    We need to limit access to some of our webcasts.
    We don’t want users to be able to give out their logins to others.
    So we want to not allow multiple logins from the same account.
    We are not using MSM.
    EE 1.6.7 -  build is 20090515.
  • #13 / Jun 12, 2009 4:03pm
    How does ouradio.com fit into this?
    Where is your login redirect going to?
  • #14 / Jun 12, 2009 4:14pm
    magder
    The redirect will take the user to the same page which has a conditional that will display a linked when logged in.
    OUradio is just a temporary template that we’re using.
    The user will stay in meetings.ou.org domain.
  • #15 / Jun 12, 2009 4:50pm
    So your return parameter is something like: return=”{segment_1}/{segment_2}/{segment_3}” ??
