Yep, that’s one of the pages:
http://www.mysite.dev/index.php/members/login
The other is
http://www.mysite.dev/index.php/forums/
I know that modules are involved here… the Discussion Forum being one of them. But how can I edit the templates for these pages? I simply need to update some formatting and it’s so badly obscured in the EE internals that I can’t find it.
Badly obscured? Say it ain’t so.
For the Forums, go to the EE control panel and click Modules, then click Discussion Forum, then click the Templates tab. The list of templates for forums will appear. Click the one you’re using (probably default), and edit until the cows come home. It’ll take that long.
User Message Templates are found by clicking Admin, then click Specialty Templates, then select whatever you want to edit.
Other user templates are available by clicking Admin, then click Member Profile Templates, then click Default, then click and edit until the cows have gone away again.
Always make duplicates of the original files before editing, of course.
