I’m getting a goofy problem where the auto xhtml is formatting backwards curly quotes after any type of punctuation. If it’s after a letter it functions fine, but after . ? and , the quotes display backwards. Anyway of fixing this? I’m using 1.6.6
January 06, 2009 11:02am
Subscribe [2]#1 / Jan 06, 2009 11:02am
#2 / Jan 06, 2009 11:34am
Welcome to the ExpressionEngine forums, boileaue.
Was this working in an earlier version?
#3 / Jan 06, 2009 11:51am
This is fixed in the latest build of 1.6.6, so a build update should fix you right up.
#4 / Jan 06, 2009 4:56pm
I have another site working on a previous version where it works. On this site, I started in build 1.6.6; so the opposite seems to be true, at least in my case. Any ideas?
#5 / Jan 06, 2009 5:00pm
What builds, specifically, are you working with? You can find that at the bottom of the control panel, under the version.
#6 / Jan 06, 2009 5:13pm
‘20081114’ I believe. Is there a new build? I’ll give that a shot tomorrow if there is. I just prefer to upgrade the cms as infrequently as possible. 😊
#7 / Jan 06, 2009 5:16pm
Yes, there is a new build, which is why I asked you to update. =)
Updating to the latest build will fix the quotes/punctuation issue.
Please confirm once you have completed the update. =)
