Basic Weblog Display Question
December 03, 2008 7:42pm
  • #1 / Dec 03, 2008 7:42pm
    Lucas Mays
    So I’m new to the Expression Engine game and am using it to build a basic content website.
    I’m wondering how to display a weblog entry by name. Is this possible?  I know that you can display with a limit and by entry_id, but I’m trying to use segments to control which weblog entry to display.
    I’m trying to display my about section content by segment essentially.
    Here’s my simple code:
    {exp:weblog:entries weblog="about_ozone" disable="categories|member_data|pagination|trackbacks"}
    {page_body}
    {/exp:weblog:entries}
    Where my weblog “about_ozone” contains multiple entries of course.
    I figured this would be simple, but perhaps I’m overlooking something or a better way to implement.
    Thanks in advance for any pointers.
  • #2 / Dec 03, 2008 9:14pm
    PXLated
    You mention segments but don’t give an example of a typical URL with the segments…So, I’ll give a general example…
    Typical URL:
    http://www.example.com/index.php/templateGroup/template/segment_3
    http://www.example.com/index.php/templateGroup/template/url_title
    Typical weblog:entries tag using a URL segment:
    {weblog:entries weblog="about_ozone" limit="1" url_title=”{segment_3}}
    That combination would display 1 entry with the URL title found in segment #3 using a template from a templateGroup.
    Does that help or am I missing what you’re after?
  • #3 / Dec 03, 2008 9:26pm
    Lucas Mays
    Thanks for your response, it just occurred me that my issue was the non-use of the url_title parameter in the weblog:entries tag.  Essentially it is the “name” I was looking for.
    Ah, to be a novice.
    Thanks again for the help, I’m finding that the simpler things are harder at my current stage…
  • #4 / Dec 03, 2008 9:34pm
    PXLated
    It’s always the simple things 😊
    Good luck with your site!
  • #5 / Dec 03, 2008 9:34pm
    Lucas Mays
    One more quick question.
    If I’m using a line of code as you suggested:
    {weblog:entries weblog=“about_ozone” limit=“1” url_title=”{segment_3}”}
    If segment_3 doesn’t exist, is it treated like segment_2?  Aka, do segment variables roll down so to speak.
    It seems to be working fine but I want to make sure I’m not using seriously bad logic.
  • #6 / Dec 03, 2008 9:42pm
    Lucas Mays
    Ha, it actually doesn’t work as I thought.  Nevermind the above, I thought I came across something automated, but it’s just normal as it should be.
  • #7 / Dec 03, 2008 9:48pm
    PXLated
    What do your links/urls look like?
  • #8 / Dec 03, 2008 10:01pm
    Lucas Mays
    Here’s what I’m trying to do:
    I have segment levels on my about page
    //my general about page
    http://localhost:8888/ee/index.php/about_ozone
    //my sub content
    http://localhost:8888/ee/index.php/about_ozone/news
    http://localhost:8888/ee/index.php/about_ozone/privacy_policy
    //my “who we are” sub content
    http://localhost:8888/ee/index.php/about_ozone/who_we_are/overview
    http://localhost:8888/ee/index.php/about_ozone/who_we_are/people_profiles
    http://localhost:8888/ee/index.php/about_ozone/who_we_are/animal_profiles
    The sub content is controlled my a left nav within the about page.
    What I’m trying to do is only use one Weblog about_ozone to hold the content for all three of these levels as they are very similar.
    Thus, to access them it will be something like:
    {exp:weblog:entries weblog="about_ozone" limit="1" url_title="{if segment_3 != ""}{segment_3}{if:else}{if segment_2 != ""}{segment_2}{if:else}{segment_1}{/if}{/if}” disable=“categories|member_data|pagination|trackbacks”}
    {page_body}
    Can you do something like this?
  • #9 / Dec 04, 2008 2:30am
    PXLated
    Answering out of order…
    First, just to make sure there is understanding, weblogs are just data containers, what’s displayed is controlled via weblog tags in templateGroups/templates that are called through the url.
    Don’t think (almost positive) you can’t put conditionals within the weblog:entries tag.
    Using EE native (normal) functionality…
    Will display the index template in the about_ozone template group
    //my sub content
    Will normally display the news or privacy_policy templates within the about_ozone template group
    Will normally display (using the url_tile) the single entry “overview” entry (etc) in the who_we_are template within the about_ozone template group
    Based on your attempted conditionals, are you trying to display all this content through just one template or are you going to have index, privacy_policy and who_we_are templates within the about_ozone template group?
  • #10 / Dec 04, 2008 8:59pm
    Lucas Mays
    I am attempted to display them all in one about_ozone template within my default site group.  It sounds like it would make more sense to parse out an about_ozone template group with templates for who_we_are, news, and privacy policy like you said.  The who_we_are would then have 3 weblog entries which I can display with url_title.
    I have a feeling I’m trying to over optimize for no reason in this case.
  • #11 / Dec 04, 2008 9:13pm
    PXLated
    It’s always a balance between optimizing with a minimum of templates and just fighting the system. You can actually run a whole site through one template (Rick Ellis did once) but it can get unwieldily with all the conditionals. I’ve gone both ways - too many templates and too few. The natural EE system is templateGroup/template/something, if you work within that structure, a lot of things are automatic. Just remember, weblogs = content/data and templates = url/display/presentation.
  • #12 / Dec 04, 2008 9:20pm
    Lucas Mays
    Werd.  Will do, and thanks much
  • #13 / Dec 04, 2008 10:39pm
    PXLated
    Did I actually help or answer your question? I got somewhat distracted here at work :-(
  • #14 / Dec 05, 2008 12:45am
    Stephen Slater
    I may have missed it while scanning through this thread, but something to make sure of when linking to the template that dynamically pulls in the weblog data is to use {url_title_path=""}.  This will automatically append the url_title to the end of your url structure.
    If you use {path=""} variable, you’ll need to rely on the url_title= parameter to pull in the specific entry.
    Make sense?
  • #15 / Dec 05, 2008 2:05am
    Lucas Mays
    PXLated - Yes you helped, and thanks.
    StephenSlater - Yes, it does make sense, I will investigate utilizing url_title_path in my implementation. I’ll be sure to holla back if I have any questions 😊
