FLV woes, it wont load into the swf
September 22, 2008 12:55pm
Subscribe [4]
  • #1 / Sep 22, 2008 12:55pm
    John Macpherson
    Hello,
    Im trying to get a flv video player to work.
    The swf loads in ok its just the video that wont seem to load.
    Iv tried using swf object and embed tags but neither will work.
    Its using AS2 and Flash CS3
    Any help greatly appreciated.
  • #2 / Sep 22, 2008 6:46pm
    e-man
    I’d say swfobject is loading the swf just fine, if I paste the swf url in a separate window I see exactly the same as what is being embedded.
    I’d check if the links to the videos are correct in Flash CS3…
  • #3 / Sep 22, 2008 10:23pm
    every time i do flash in a dynamic environment that requires an external file, like flv, xml, or some such, something almost always goes awry. check your paths. don’t assume that just because flash and the xml are in the same directory that the path will be relative to the flash. if i remember correctly, it’s relative to the page url. milage can very though depending on what embed method you are using.
  • #4 / Sep 23, 2008 6:32am
    Mark Bowen
    Hiya TheStig,
    I could be wrong as it might be due to the way your .swf file has been coded, no way of knowing so just guessing at this point but when I visited the link that you have posted above the link to the .flv file is coming up as :
    link removed at request of initial poster
    When I point my browser to that URL the file doesn’t seem to exist and just pops up with your site instead. Are you sure that is the correct URL for your .flv file first of all?
    Hope that helps a bit.
    Best wishes,
    Mark
  • #5 / Sep 23, 2008 12:39pm
    John Macpherson
    Thanks for the replies guys.
    It was a bug ( i think)in Flash. I switched over to the jeroen player and it worked fine.
  • #6 / Sep 23, 2008 12:58pm
    Mark Bowen
    Glad you have it all sorted now.
    Best wishes,
    Mark
