Icons in Control Panel not appearing
July 15, 2008 9:55am
  • #1 / Jul 15, 2008 9:55am
    tlclawrence
    After installing EE with PHP running as a cgi-bin process everything is working fine except there are icons missing in the Control Panel.  It appears that these icons are .png files that are located in the themes/cp_globla_images folder.  I am pretty sure permissions are all right.  Not sure if a path is incorrect somewhere to access these image files.
    Any ideas?
  • #2 / Jul 15, 2008 10:13am
    Wonder if they got corrupted in transit.  If you open the image directly, does it show up ok?
  • #3 / Jul 15, 2008 11:37am
    tlclawrence
    If I try to open the images directly I get an ‘Application Error’ from my hosting server.  This makes me think that it is something to do with the cgi-bin.
    The thing I don’t understand is that most of the control panel theme looks fine.  So how is it that it is restricting just the cp_global_images?  I’ve tried giving that folder and all its contents full permissions, but it doesn’t help.
  • #4 / Jul 15, 2008 12:31pm
    And sounds like it’s just happening with the png as well- correct?  Are the gifs and such showing up?  What browser are you viewing with?  If IE, try something else just to see.
    And what build/version are you running?  This is actually vaguely familiar.  That said- might want to just delete and then upload fresh copies of those images.  See if that helps at all.  May just be corrupted.
  • #5 / Jul 15, 2008 12:38pm
    tlclawrence
    I’ve tried both Firefox and Safari.  Problem exists with both.  Have tried deleting and re-uploading several times. No luck!  It is all image files (.jpg, .gif, .png, etc.)
  • #6 / Jul 15, 2008 1:07pm
    OK- if you just ftp up an image completely unrelated to EE and try to view it- same problem?
  • #7 / Jul 15, 2008 3:35pm
    tlclawrence
    Correct.  It appears as if all images if they reside anywhere inside the cgi-bin do not work.
  • #8 / Jul 15, 2008 4:27pm
    You might want to talk to your host, but I would not generally expect images inside cgi-bin; this directory is for .cgi programs.
  • #9 / Jul 15, 2008 6:44pm
    tlclawrence
    Thanks.
  • #10 / Jul 15, 2008 6:44pm
    tlclawrence
    Thanks for the help.  That was the key.  The images and themes folders don’t belong in the cgi-bin.  That solved it.  That was stupid of me.
  • #11 / Jul 15, 2008 6:53pm
    No worries 😊 The important thing is you solved it… Closing this thread, if anything else comes up kindly start a new one, thanks.
