I’ve purchased the personal use version after playing with EE and if I can get the following solved for my client then I can bump it up to commercial.
The challenge is this.
I was hoping that the Photo Gallery and a standard Web Blog entry area could be associated with each other in such a way that as you filled out an entry you could associate a number of images from the gallery with it and have them displayed once published.
You are asking, why the gallery? Answer is easy, I am not sure of any other way of doing this.
I need a method that would allow the user to upload as few as 1 and as many as 5 images for a weblog entry. Idealy they would be able to upload their images and then be able to select the specific image order if not from a visual grid of thumbs then from a named list of the uploaded images. A drop down list for the primary image, secondary, tertiary and so on. Also it would be ideal if the system created a thumb version of the image for display within the entry and the (max width / height / maintain aspect) values were set to a default value so they wouldn’t have to worry about it.
Is there an extension or method of doing this? Have I missed something obvious?
Thanks in advance for any help.
Paul
