Display most recent where custom field is not empty
October 10, 2007 4:28pm
  • #1 / Oct 10, 2007 4:28pm
    tripp
    Can’t seem to get my head around this one…
    I need to display the title of only the most recent post where a custom field (video) contains a value. I understand that I need to drop in a conditional along these lines:
    {exp:weblog:entries weblog="news" [not sure what would go here]}
         {if video != ""}
              {title}
    {/exp:weblog:entries}
    ...but I don’t know how to write the exp:weblog:entries query. My attempts have either given me no results or way too many.
    ExpressionEngine 1.6.0
    Build:  20070918
  • #2 / Oct 10, 2007 4:33pm
    Do you need to also limit by the custom field, so only have entries where video is filled out? Or is it only the title that you need to conditionally show.  If the latter, then the weblog entries tag would just be your standard one with normal parameters for limit.
  • #3 / Oct 10, 2007 4:42pm
    tripp
    Yes, that’s what I’m trying to do.
    I need to display the title for only the most recent entry in the weblog where the video field contains data.
  • #4 / Oct 10, 2007 4:45pm
    If you need to show *only* entries that have that custom field filled out, then you’ll need an extension to do so, have a look in the Extensions forum for “Custom Fields in {exp:weblog:entries} by Mark Huot.
    If you use conditionals for this, you’ll still be processing those entries, you’re just hiding them from view.
  • #5 / Oct 10, 2007 5:04pm
    tripp
    The good news is that Mark’s extension is exactly what I need. The bad news is that using it involves modifying mod.weblog.php, which isn’t allowed on this particular project.
    Any other ideas?
  • #6 / Oct 10, 2007 5:14pm
    I’m going to have to move this to how-to at this point; but the only other options are a custom extension/plugin/module or query.  There are feature requests for this and you could add your voice; but if you need it immediately, then a custom query is your best bet.
