help with IF and assigned_variables
October 03, 2007 3:22pm
  • #1 / Oct 03, 2007 3:22pm
    wineknow
    I have the following:
    {assign_variable:my_var="test"}
            {if my_var == "test"}
                <h1>yes</h1>
            {if:else}
                <h2>no</h1>
    why does this not work?
    (and by work I mean return yes)
    -kevin
  • #2 / Oct 03, 2007 3:27pm
    Hi, Kevin! Welcome to the forums.
    Try it like this:
            {if "{my_var}" == "test"}
                <h1>yes</h1>
            {if:else}
                <h2>no</h1>
  • #3 / Oct 03, 2007 5:26pm
    wineknow
    ok, while that will work, let me expand on what I am really trying to do:
    my url structure is as follows.
    assume I am Using Category URL Titles In Links (not ID’s)  and my Category URL Indicator is “region” and my weblog is “section1”
    [I am also using redirects to remove index.php]
    then from what I understand, the URLs for categories would be
    domain.com/section1/region/category_title1
    domain.com/section1/region/category_title2
    domain.com/section1/region/category_title3
    and my blogs would be
    domain.com/section1/blogtitle1
    domain.com/section1/blogtitle2
    domain.com/section1/blogtitle3
    first question, is the above correct?
    if so, second question.
    - on the category pages, I want to display something different then on a “blog” page.
    so I guess I need to do something like the following
    {if segment_2 == "region"}
      category stuff
    {if:else}
       display blog detail
    all that is fine to do, but I don’t like hardcoding stuff like that—especially if it is in a few templates AND I then go to change my ‘Category URL Indicator’ to something else…..
    so what I thought I would do is the following:
    {assign_variable:my_category_url_indicator="region"}
    {if segment_2 == my_category_url_indicator}
      category stuff
    {if:else}
       display blog detail
    but the above does not work…..
    I have just started learning EE, so I hope this isn’t too dumb of question.
    -kevin
  • #4 / Oct 03, 2007 6:07pm
    First question - did you read the documentation explaining URLs? Your URLs have nothing to do with the weblog, but everything to do with the template group and template name.  Check out the docs page on Understanding EE URL.
    Your category URL indicator, though, is site-wide, and is not likely to change often; I’ve never seen a situation where it does change… ever.  This is a really important, fundamental decision that you should make now and stick with.
