Display div and entry only if there's a current entry?
September 15, 2007 11:36pm
  • #1 / Sep 15, 2007 11:36pm
    csavannah
    I’m working on a blog and I’d like a site news bar to appear at the top of it, but I want it only to appear if theres news. I’ve the weblog for it to only display one entry, but I’m not sure how cause the div and entry to appear only if there’s a current entry. Naturally I’d either set an entry to expire or expire it manually.
    The code I have is this:
    {exp:weblog:entries weblog="sitenews" orderby="date" status="open" sort="desc" limit="1" show_expired="no"
    show_future_entries="no" disable="categories|custom_fields|member_data|pagination|trackbacks"}
    {if count =="1"}
    <div id=“header”>
    <div id=“sitenewsbar”>
    Site News {current_time format="%M. %j%S, %Y:"}
    {body}
    {/exp:weblog:entries}
    </div>
    But all that does is show Site News {body}
    Any suggestions on how to get this done?
  • #2 / Sep 16, 2007 12:07am
    chrispiciullo
    Hey Brandon,
    Remove custom_fields from the disable= bit of your entries tag.  That’ll bring back the actual content of your “site news” posts.
    Chris
  • #3 / Sep 16, 2007 3:55am
    julianps
    If I understand you right, can you use a conditional; so that the complete tag (inc HTML) only appears when there’s something to show?
    <!-- {if count =="1"} -->
    <div id="header">
    {if body}
         <div id="sitenewsbar">
                  {body}
         </div><!-- s//itenewsbar -->
    </div><!-- h//eader -->
    <!-- /div -->
    <!-- {/if} -->
    You can set expire dates in any number of ways, not least when you create the article in the first place.
    JiF
  • #4 / Sep 16, 2007 10:10am
    csavannah
    Cool, a combination of both suggestions solved the problem. Need to turn custom_fields back on AND check for the presence of {body}. Thanks guys!
