Problem with Query Module
August 29, 2007 7:22pm
  • #1 / Aug 29, 2007 7:22pm
    Jeri Letman
    I have a custom query that prints out fine.
    This code prints out all the records
    {exp:query limit="5" paginate="bottom" sql="SELECT commission_id,payment_id,receipt_id,product_id,affiliate_id,entry_date FROM exp_aff_commissions ORDER BY entry_date DESC"}
    when I try to limit the output to just the logged in member I used this statement
    {exp:query limit="5" paginate="bottom" sql="SELECT commission_id,payment_id,receipt_id,product_id,affiliate_id,entry_date FROM exp_aff_commissions WHERE affiliate_id ='{member_id}' ORDER BY entry_date DESC"}
    This outputs nothing. The SQL statement would print out values if the value of member_id was merged into the statement.
    I also tried this:
    {assign_variable:sql_statement="SELECT commission_id,payment_id,receipt_id,product_id,affiliate_id,entry_date FROM exp_aff_commissions where affiliate_id ={member_id}"}
    {exp:query limit="5" paginate="bottom" sql="{sql_statement} ORDER BY entry_date DESC"}
    That didn’t work either. I put {sql_statement} in the template to make sure that the SQL statement was correct, and it was.
    Am I missing something, or can this not be done?
    Jer
  • #2 / Aug 29, 2007 8:22pm
    Derek Jones
    Global variables are parsed at the very end of the template parsing, Jeri, so the Query is being executed before {member_id} is evaluated.  You need to use PHP on Input stage parsing and use:
    <?php global $SESS; echo $SESS->userdata['member_id'];?>
  • #3 / Aug 29, 2007 8:26pm
    Jeri Letman
    Thank you.
    I will do that.
    Jer
