3rd Party Shopping System integration with Expression Engine
July 02, 2007 12:31am
  • #1 / Jul 02, 2007 12:31am
    1px Solid
    Hi, I’m looking at creating a site driven by Expression Engine, but want to use an external shopping system ( http://www.xsilva.com/ ) to sell products.
    Before I get too deep into the project, I want to know how easy it is to integrate a 3rd Party Shopping System with Expression Engine. By this I primarily mean including products from the shopping system on the homepage of the site which is filled with Expression Engine content.
    A brief overview of the homepage structure…
    ee_header
    ee_news
    3rdparty_shopping_products
    ee_blog
    ee_footer
    The system I’m looking to integrate is written in PHP, so I’m thinking a php include might work?
    Any advice would be hugely appreciated.
    [Moderator Edit: Moved to How To forum]
  • #2 / Jul 02, 2007 12:20pm
    I’m going to zip you over to ‘How to’ as it’s a bit of a better fit for this type of question.  That said- a php include- or even javascript- might be a good option.  Though sometimes classes clash.  If it holds the info in a mysql database?  I’d install the cart in the same db as EE- and then use the query module to pull out the product info.  To me, that would be the easiest way- gives you all the flexibility of EE on the design end of things.  But- it depends a bit on what you want to do.
  • #3 / Jul 02, 2007 7:34pm
    1px Solid
    Thanks Robin. I haven’t installed this 3rd Party system yet. But you’re right, might be easier installing this in the same database and using the query module to display the items.
  • #4 / Jul 03, 2007 7:38am
    kenny2
    Would be interested to hear how you get on. Although xsilva seems more suited to bricks and mortar stores it has a lot of useful back end functions that most ecommerce solutions lack.
