Setting up a CMS using Expression Engine
July 01, 2007 8:03am
Subscribe [0]
  • #1 / Jul 01, 2007 8:03am
    rcsm
    I’m new to EE and I’m trying to determine the best logical structure for setting up the following site I’ve designed:
    http://63.147.126.13/hyatt_weber/rd2/case_study_charcoal.html
    From my limited knowledge of EE, I would imagine that I’ll set up templates for each unique section of content (About Us, Expertise, etc), and then set up weblogs for each of those sections as well. Some of the sections will just be multiple pages (case studies, for example) whereas others will have subsections (About Us).
    Basically, my question is: is multiple weblogs/templates the way to handle this, or should I be using catagories for some of this? I’m a bit unsure how catagories would work, but is this something for which they would be appropriate?
    Any thoughts?
  • #2 / Jul 01, 2007 8:36am
    Rob Allen
    I’m pretty new to EE as well but have played with it enough to give you some pointers.
    I would suggest making at least 2 weblogs, the main weblog could cover your home page and misc pages (about, contact, privacy etc) - for this you’d need your index template for your home page, a template to show your misc page info, and a template for your contact form.
    Your case studies would be a separate weblog with a separate set of templates, again an index template for your main casestudies page, and another for displaying each case study.
    Of course that’s only one way to do it. You could have a template group for each page/area, this would be useful if you had totally different layouts on different pages. The only use for categories that I can see from your example would be to categorise your case studies.
    No doubt some regular EE’ers will be along to give you the best advice!
  • #3 / Jul 01, 2007 8:41am
    rcsm
    Thanks, that is helpful!
    But I’m still a bit unsure how I would handle subsections? For example, if the about section has 5-6 subpages (some of which will have their own subsections), wouldn’t those need to be categories of an ‘about’ weblog?
  • #4 / Jul 01, 2007 1:06pm
    Rob Allen
    Yes that would be an example of where categories would come into use. What I would do is create a template set called “about”, inside this template group you would have an index template which lists all your sub pages + extra info, then one template to show a sub page.
  • #5 / Jul 01, 2007 9:18pm
    rcsm
    That makes sense. I’ll give it a shot and see how it pans out.
  • #6 / Jul 03, 2007 3:24pm
    OrganizedFellow
    This is what is SOOO amazing about this community: no where, will you find a newb asking for help, only to be assisted by another newb.
    @dpachner: please post a URL so we can check it out?!
