After upgrading to 1.6, I have no drop-down menu to choose control panel theme, either in System Preferences or in My Account > Customize Control Panel. See images below
June 21, 2007 5:22pm
Subscribe [0]#1 / Jun 21, 2007 5:22pm
#2 / Jun 21, 2007 5:38pm
Check your /themes/cp_themes/ folder. ExpressionEngine needs to read its contents, so make sure it has permissions that will allow that on your server.
#3 / Jun 21, 2007 5:41pm
Hi, Andrea. Before you were using 1.6, which CP theme were you using?
In your cp_themes directory, which themes are there?
#4 / Jun 21, 2007 5:49pm
Permissions are OK on the /themes/cp_themes folder.
I was using the 31Three theme before I upgraded, and removed it before upgrading. I have Classic and Default now in the cp_themes directory. When I first upgraded, I had a download with only the Default theme. I got a new download that included Classic an hour or so later and added it.
#5 / Jun 21, 2007 5:51pm
What are the permissions on that folder and for the folders inside of it? The reason I ask is that the only way there would be no select is if EE was unable to read any folders from that directory.
#6 / Jun 21, 2007 5:55pm
Permission are 755 for all the folders within themes. I also have a set-up where I need to copy the cp_themes directory into the system directory for the CSS to be read—this has permissions of 755 as well. Could this possibly be the issue, though?
#7 / Jun 21, 2007 6:21pm
Andrea, look up the value of cp_theme for your record in exp_members. Does that theme mentioned there still exist? If it doesn’t manually change the name to default, and see if that fixes things.
#8 / Jun 21, 2007 6:32pm
Strange. There was nothing in that database field. Adding default there fixed some minor display issues I was having with the cp theme, but there are still no select boxes.
#9 / Jun 21, 2007 7:06pm
Yeah, Sue, that would fix a display issue for the theme, but the list of themes and the select box is still tied to reading the contents of that directory.
I guess, send me FTP and EE Control Panel access so I can take a look, please.
#10 / Jun 21, 2007 7:20pm
I figured it out—my Theme Folder Path in General Configuration was wrong. Once I fixed it, I got the select boxes.
Thanks for your help!
