No Control Panel Theme
June 21, 2007 11:16am
Subscribe [4]
  • #1 / Jun 21, 2007 11:16am
    stinhambo
    Just in case it should be posted here I have attached a screenshot of my Control Panel which is installed on a local server.
    It is version 1.6 and was downloaded about an hour ago.
  • #2 / Jun 21, 2007 11:59am
    Stinhambo, did you make sure you uploaded all parts of the themes folder?
  • #3 / Jun 21, 2007 12:00pm
    stinhambo- I hit you up in the ‘Install’ thread which is probably a better fit.  But I’m going to leave this one here for now in case other folks run into it as well.
    Not sure if this is a bug or an individual quirk at this point.  If you send me over superadmin access in a pm, I can take a closer look and perhaps figure that out.  (I’m going on the assumption the theme folder is correct- from the other thread, sounds like it is.  I’m also going on the assumption all was up and working before- otherwise it could be a server related security restriction.  But again- doesn’t sound like it in this case.)
  • #4 / Jun 21, 2007 12:05pm
    stinhambo
    It is on a local server which hosts 1.52 no problems at all.
    It hasn’t worked properly at any point. I dropped all tables, deleted the folder and deleted my download just to be sure.
    So new download, new database and new install… Same problem!
    I can’t figure it out at all!!
    I’ll upload to a live server and PM you the details so you can see yourself.
  • #5 / Jun 21, 2007 12:08pm
    This kb entry applies even to 1.6. *winks*
  • #6 / Jun 21, 2007 12:18pm
    stinhambo
    Well bugger me!
    Perhaps I need to update my XAMPP installation?
    Thank you!!
