problems with php in code not working in EE
June 21, 2007 1:14am
  • #1 / Jun 21, 2007 1:14am
    ummedia
    Hi I am having problems using php and could do with someone showing me the way all I want to do is set a variable with php and then echo it in the exp call, I actually want to set a variable then get it incremented each time a new entry is used but need to get it working to start off with. In the original template this works and when I run it through EE it doesnt any idea or pointers please
    <br /> <?php<br /> $categorycount = 0;<br /> ?><br /> <table><tr><br /> {exp:query sql="SELECT count( exp_category_posts.entry_id ) AS count,<br /> exp_category_posts.cat_id, exp_categories.cat_name<br /> FROM exp_categories, exp_category_posts<br /> WHERE exp_category_posts.cat_id = exp_categories.cat_id<br /> GROUP BY exp_categories.cat_name"}<br /> <td width=169 height=93 valign=top><a href="http://{path=intelart/category}C{cat_id}/">http://www.ummedia.com/MY_SITES/fatlava/Resources/suitcase.gif</a><br /> {cat_name} ({count})(<?php echo $categorycount; ?>)</td><br /> {/exp:query}<br /> </tr></table> <br />
    many thanks adan
  • #2 / Jun 21, 2007 1:28am
    ummedia
    please ignore parsing was turned off in my templates, I just cant now get the count to increment by one this is the code
    <br /> <?php<br /> $categorycount = 0;<br /> ?><br /> <table><tr><br /> {exp:query sql="SELECT count( exp_category_posts.entry_id ) AS count,<br /> exp_category_posts.cat_id, exp_categories.cat_name<br /> FROM exp_categories, exp_category_posts<br /> WHERE exp_category_posts.cat_id = exp_categories.cat_id<br /> GROUP BY exp_categories.cat_name"}<br /> <?php $categorycount++;?><br /> <td width=169 height=93 valign=top><a href="http://{path=intelart/category}C{cat_id}/">http://www.ummedia.com/MY_SITES/fatlava/Resources/suitcase.gif</a><br /> {cat_name} ({count})(<?php echo $categorycount; ?>)</td><br /> {/exp:query}<br /> </tr></table> <br />
    I am not a coder so it must be something I am doing when the exp loops does it not know that it is being incremented. It always returns the count of one please help me before I go insane with something the should be sooo easy
    many thanks
    Adam
    regards Adam
  • #3 / Jun 21, 2007 8:48am
    ummedia
    please could someone help. at least tell me I have no idea what I am doing and give me some direction.
    many thanks
    Adam
  • #4 / Jun 21, 2007 9:02am
    ummedia
    sorted it I just had to change the count in the query to count_1 and all was well
    Adam
