PHP Errors, Relationships, Undefined Offset
January 24, 2014 5:14pm
Subscribe [5]
  • #1 / Jan 24, 2014 5:14pm
    bromtec
    Hello,
    Working locally in MAMP.  Just upgraded from 2.4 to 2.7.3.
    Was previously using Multi Relationships and ran into relationship errors after the upgrade, so restored everything and completely removed / uninstalled multi relationships and the field associated with it, and then upgraded again.
    I’ve created a new relationship field, and it’s outputting what I want, but is also giving errors when logged in…
    A PHP Error was encountered
    Severity: Notice
    Message:  Undefined offset: 0
    Filename: relationship_parser/Tree_builder.php
    Line Number: 536
    I get anywhere from 1-5 of the above, and then the following always at the end.
    Severity: Warning
    Message:  Cannot modify header information - headers already sent by (output started at /Users/paul/all/rsw_dev/public_html/system/codeigniter/system/core/Exceptions.php:170)
    Filename: core/Common.php
    Line Number: 412
    It happens on most, but not all entries.  The errors come with something as simple as including,
    {related_projects}
    {/related_projects}
    (literally just the start and end tag, nothing in between).
    Removing the above from the template will eliminate the errors (and the desired output, unfortunately).
    Any ideas / help would be greatly appreciated.
  • #2 / Jan 31, 2014 5:14am
    nuvole
    I have the same problem. My errors are:
    Severity: Notice
    Message: Undefined offset: 2
    Line Number: 532
    Severity: Notice
    Line Number: 532
    Severity: Warning
    Message: Cannot modify header information - headers already sent by (output started at public_html/system/codeigniter/system/core/Exceptions.php:170)
    Line Number: 412
    when I’m lodged in.
    This happened when I was working on a Grid field, just after creating a new field.
  • #3 / Feb 03, 2014 5:47pm
    bromtec
    no solution here yet, but was curious… are you running 2.7.3 as well?
  • #4 / Feb 04, 2014 3:06am
    nuvole
    Yes, v2.7.3.
  • #5 / Mar 03, 2014 6:20pm
    Scott Harrington
    Same problem too, anyone found a solution yet?
  • #6 / Mar 05, 2014 11:24am
    bobh
    Exactly the same issue here, output is good but lots of errors. who’s got a patch?
  • #7 / Dec 11, 2014 8:27am
    jefinho
    Same problem here! Anyone already found a solution?
  • #8 / Dec 11, 2014 11:18am
    bromtec
    It seems to go away after I logout, so I’ve just been living with it the way it is…
