Heater problem - can't find any white spaces
November 24, 2013 5:39am
  • #1 / Nov 24, 2013 5:39am
    überfuzz
    I’m tinkering with a site that’s quite old by now. It’s based on codeigniter 1.7. Now I get this message:
    A PHP Error was encountered
    Severity: Warning
    Message: Cannot modify header information - headers already sent by (output started at xxxxxx/application/config/config.php:1)
    Filename: libraries/Session.php
    Line Number: 662
    When I google this topic everyone point towards possible white spaces in the referred file. But I can’t find any in my config-file. I’m pretty sure this was honky dory when I did the site. Any suggestions on what I should search for errors..?
    Cheers!
  • #2 / Nov 24, 2013 7:28am
    Tpojka
    I remember bugs related to byte ordering mark.
    What W3C says with example.
    I started from this page, but you could find more sources very easy.
    Try to save (custom made) file(s) without bom.
  • #3 / Nov 24, 2013 7:34am
    überfuzz
    What do you mean?
  • #4 / Nov 24, 2013 7:50am
    Tpojka
    Find all files that are included in runtime (controller, model, custom made helper, custom made library…) and encode it to UTF-8 without BOM. In Notepad++ it is in Menu Encoding. Than save the file.
    edit: or try it with config.php file first.
  • #5 / Nov 24, 2013 10:24am
    überfuzz
    ...and encode it to UTF-8 without BOM.
    Sry for being such a noob about this, but whats a BOM?
    Edit, by the way, is it possible to turn off warnings?
  • #6 / Nov 24, 2013 10:38am
    Tpojka
    Just google for BOM. At wiki there is text too.
    I am not an expert but witnessed saving file as UTF-8 without BOM could solve that problem.
    I pointed how to set it in Notepad++, but every editor should have option for formating edited file(s).
    For disabling warnings, you have to set code in index.php (the root one) with some of wanted levels.
  • #7 / Nov 24, 2013 12:34pm
    überfuzz
    Hmm.. It seems it was an upper/lower case letter issue. When I change the meta casting from: charset=utf-8 to charset=UTF-8 the warning vent away.
    However, now some characters are �. An thought on that..?
  • #8 / Nov 24, 2013 12:48pm
    überfuzz
    No hold it…
    I tried to duplicate the error, so I changed back and forth between lower and upper case. The issue is back, no matter how I set up the charset in the config-file.
  • #9 / Nov 24, 2013 1:38pm
    Tpojka
    I am assuming that you are talking about line in config.php:
    $config['charset'] = 'UTF-8';
    I was not talking about that in posts before, but I was talking about this:
    1. download application/config/config.php
    2. open it in Notepad++*
    3. go to encoding menu
    4. convert to UTF-8 without BOM
    5. save file
    6. upload and replace
    *already said other rich editors have their options, but I can point on Notepad++ now
    That is what I suggested in my first post too.
    Why don’t you try?
