I’ve gotten a custom controller set up in my EE install and I’m trying to use an EE template with the custom functions etc I need to use.
<?php if (!defined('BASEPATH')) exit('This cannot be hit directly.');
class Example extends EE_Controller {
function __construct() {
parent::__construct();
// get EE
$this->EE = $this->core->EE;
// get EE's template library
$this->EE->TMPL = $this->EE->load->library('template');
function index() {
$this->EE->TMPL = new EE_Template();
//pick our template
$this->EE->TMPL->run_template_engine('site', 'form');
}This controller code successfully loads up my EE template, but I haven’t had any luck parsing the tags, or sending in values for the tags. What should I do?
I realize I could build modules for custom code etc, but I need to allow for custom controllers for outside Kohana and Symfony code the EE install needs to make friends with.
I tried using the $this->EE->TMPL->parse_variables() function that that didn’t seem to let me swap out the variables either.
For example, my template has code in it like this:
<title>{meta_title}</title>Any suggestions?
