when using orderby="title" half my posts dissapear
September 23, 2013 2:02am
  • #1 / Sep 23, 2013 2:02am
    tobypowell
    Hi
    when using orderby=“title” half my posts so for example all posts with a title from A-L display fine, but nothing else after L appears.
    I’ve tried turning off all third party plugins etc, and testing with different channels and i have the same result. If i remove the orderby=“title” then all my posts appear… i really need them alphabetically and asc.
    Im running ee 2.7.0 all plugins are now off and everything else except this seems to be fine. I’ve testing on a local evironment and a live server and am getting the same thing. I’ve also tried with various different channels, and same again.
    here is an example of a cannel code im using:
      <div class=“brands_container”>
        {exp:channel:entries channel="brands" status="open" orderby="title" sort="asc"}
        <div class=”{position_in_alphabet}”>
        {title}
          </div>
  • #2 / Sep 23, 2013 7:29am
    Boyink!
    If you have more than 100 entries try setting a higher number of results using the limit parameter.
  • #3 / Sep 23, 2013 8:56am
    tobypowell
    Hi, there is actually 97 posts, but I had already tried that but i didn’t help. Any other ideas, much appreciated
    thanks
  • #4 / Sep 24, 2013 12:29am
    tobypowell
    Hi, I’ve just upped limit=“200” and this resolved the problem, so thanks very much for the advice it sorted it. This can be considered closed. Thanks again
  • #5 / Sep 24, 2013 9:49am
    travisb
    There should be a button for you (OP) to mark this question as “Has a Solution”.
