How to? ee()->db->query(""); inside Expression Engine templates
September 17, 2013 6:47am
  • #1 / Sep 17, 2013 6:47am
    A.Daniel
    Hi, how can i query using CI methods?
    let’s say we have a expression engine template
    and instead of using
    {exp:query sql="SELECT distinct field_id_200 FROM exp_channel_data"}
    using this
    ee()->db->query("SELECT distinct field_id_200 FROM exp_channel_data")
    what files should i include?
    or how can i access the db files inside config/ in order to connect to db and get the files…
    can any one give me one simple example, i do not understand CI,
  • #2 / Sep 19, 2013 12:16pm
    Focus Lab Dev Team
    Before diving into an answer:
    If you don’t understand CI, why do you want to query the DB in this way?
  • #3 / Sep 19, 2013 12:39pm
    A.Daniel
    i wanted to build a more complex query based on multiple option selected on a form, and that involved some complex conditional and query string concatenation.
    Inside exp:query tag that wasn’t just possible.
    Finally i found a solution using php code as input +query tag.
    But anyway this code $query = $this->EE->db->query($sql);
    foreach ($query->result() as $row)
    echo $row->field_id_30."
    is ok?
    In my case it’s working
    I have some understanding on OOP, that’s why i said i don’t understand CI, but i want to dig in, because i see the ee is not 100%  solution to all problems, even with helps from third party plug ins and extensions…
  • #4 / Sep 19, 2013 12:48pm
    Focus Lab Dev Team
    Yes, that should work fine. I do have one suggestion. In the event that your query doesn’t return any results you would end up with an error in the foreach loop. To avoid that you can add a conditional which can also serve as an {if no_results} equivalent.
    if ($query->num_rows() > 0)
    ...i see the ee is not 100%  solution to all problems, even with helps from third party plug ins and extensions…
    No software will be 100% solution to all problems 😊
  • #5 / Sep 19, 2013 3:48pm
    A.Daniel
    Of course , no software would be the perfect solution. But for an simple option like this http://ellislab.com/forums/viewthread/237951/ i must learn how to build a plugin, and integrate it in admin,  in order to solve my problem.
