Good evening everyone.
This is probably a really simple fix, Its just driving me crazy.
Im building a store site with cartthrob and it have a fluid grid bootstrap layout.
It has a 12 column grid
span 3 for cart
span 9 for products
within the span 9 there is
span3 for products per row.
My problem is i cant figure out what to change to make it so I can have more per line on the nested span3. I can change the width of the products by choosing span2, but there are still only 3 items per row
Ill try paste the page code here any help would be greatly appreciated
{preload_replace:template_group="store"}
{preload_replace:template="index"}
{embed="{template_group}/_header" title="Shopping Cart" template_group="{template_group}" template="{template}" }
</head>
<body>
{embed="{template_group}/_navbar" template_group="{template_group}" template="{template}"}
{embed="{template_group}/_subhead" template_group="{template_group}" template="{template}"}
{!-- since we're using twitter bootstrap, the main content area is designated "container", or some other specific classes depending on your requirements--}
<div class="container">
{!-- twitter bootstrap breaks up content into rows. The main section of this template is all one row. Rows can also be broken up into more rows --}
<div class="row">
{!-- twitter bootstrap breaks up (by default) pages into a 12 column grid. span3, span9 designate how much space these sections will take up --}
<div class="span3">
<div class="bs-docs-sidenav">
{embed="{template_group}/_leftnav" template_group="{template_group}" template="{template}"}
</div>
</div>
<div class="span9">
<section id="main">
{exp:channel:entries channel="store_kitchen_units_price_group_1" limit="30" dynamic="no"}
{if count==1}<h2>Available Products</h2><p><ul class="thumbnails">{/if}<br />
{switch="<div class='row'>||"}<br />
<li class="span2"> <br />
{exp:cartthrob:add_to_cart_form<br />
entry_id="{entry_id}"} <br />
<div class="thumbnail"><br />
{if unit_image}{unit_image}<br />
{if:else}<br />
<a href="http://placehold.it/300x200">http://placehold.it/300x200</a><br />
{/if}<br />
<div class="caption"><br />
<span class="unit_title">{exp:cartthrob:item_options entry_id="{entry_id}" }<br />
{select}<br />
<option {selected} value="{option_value}">{option_name} {price}</option><br />
{/select}<br />
{/exp:cartthrob:item_options}</span><br />
<br />
<br />
{if unit_price}<br />
<span class="unit_price">Price: {unit_price:plus_tax} </span><br />
<br />
{/if}<br />
<br />
Quantity: <input type="text" name="quantity" size=5" value="" /><br><br />
<input type="submit" value="Add to Cart">{/exp:cartthrob:add_to_cart_form}<br />
<br />
</div><br />
</div><br />
</li><br />
{switch="||</div>"}<br />
{if count==total_results}</ul><!-- end row -->{/if}<br />
{/exp:channel:entries}<br />
<br />
<br />
</section><br />
</div><br />
<br />
</div><br />
</div></p>
<p> {embed="{template_group}/_footer" template="{template}" template_group="{template_group}"}
