EE 2.5.5
Windows IIS
PHP 5.3.21
I am working on an upload area where members can upload large files via a safe cracker stand alone form on the front end.
I have been experimenting with Simple S3 Uploader, Channel Files and the some raw S3 File Upload source code seen here: http://undesigned.org.za/2007/10/22/amazon-s3-php-class
I have bumped up the following PHP Settings:
upload_max_filesize = 1500M
max_input_time = 7200
memory_limit = 128M
max_execution_time = 7200
post_max_size = 1800M
session.gc_maxlifetime = 7200
And I have also added the following config settings to the expression engine’s config file:
$config[‘cp_session_ttl’] = 7200;
$config[‘user_session_ttl’] = 7200;
Problems I have found to date (also replicated on a co-workers machine, different premises and internet connection)
When logged in to EE and trying to upload a 30MB file via a Simple S3 Uploader on a safe cracker form I get this error after a few minutes: Error 101 (net::ERR_CONNECTION_RESET): The connection was reset.
I also tried a 30MB file using a Channel Files Field on Safecracker and it stopped at 10MB sometimes 13MB depending on connection speed, which equated to about 2 minutes.
Channel Fields also stops around the same mark when uploading in a new entry in the CP too.
As far as I can tell it is not the server because both myself and a co-worker have successfully uploaded 700MB files a number of times via the raw S3 upload code: http://undesigned.org.za/2007/10/22/amazon-s3-php-class
I am so close but I think EE is dropping the session out or stopping the script or interrupting the connection some how.
Can anyone help?
