I am trying to resurrect one of my old sites that has been offline for a few years now. I am having a problem with the images displaying. All I get is {images limit="1"} {/images}
http://blogitspain.clouddesigners.co.uk/ is the URL
Mark
May 28, 2013 11:19am
Subscribe [2]#1 / May 28, 2013 11:19am
Mark
#2 / May 30, 2013 4:51pm
What version of EE are you using, and for which Add-on are you using the “{images limit=“1”} {/images}” variable pair?
If you are seeing the variable pair on the rendered template, it usually is because the Add-on it is associated with isn’t enabled, so the variable pair doesn’t get parsed, and it just gets inserted into the rendered page as is.
#3 / May 31, 2013 4:01am
Thanks for the reply.. I will need to check what add on it was using. I didn´t build the site and the dev has gone awol. I am using 1.78
