Help with PHPMailer and creating libraries in general
April 30, 2013 5:28am
  • #1 / Apr 30, 2013 5:28am
    Cgull
    Hello,
    Using codeigniter 2.1.2
    I am developing a site where I email a few forms with codeingiter email library.
    Everything worked find until today when one of the emails gives me an error.
    I didn’t change anything in the way I am sending the emails, but this one just fails.
    So, I did some research and found the PHPMailer plugin.
    Trying to work with this plugin gives me errors as well.
    So I have a few questions.
    I have downloaded the PHPMailer package.
    I put everything in: libraries/phpmailer/
    I change the file name: class.phpmailer.php to phpmailer.php
    In this file I added these lines:
    <?php if ( ! defined('BASEPATH')) exit('No direct script access allowed');
    $CI =& get_instance();
    $CI->load->config('phpmailer', TRUE);
    First general question here:
    I use ion_auth in my site, when I look at their library file I don’t see they use: $CI =& get_instance() they just use the normal $this, so why is it working for them and not for me?
    Then I created a file in: config/development/phpmailer.php: (My ENVIRONEMENT is set to development)
    $config['SMTPAuth'] = true;                  // enable SMTP authentication
    $config['SMTPSecure'] = "ssl";                 // sets the prefix to the servier
    $config['Host'] = "smtp.gmail.com";      // sets GMAIL as the SMTP server
    $config['Port'] = 465;                    // set the SMTP port for the GMAIL server
    $config['Username'] = "[email protected]";     // GMAIL username
    $config['Password'] = "mypassword";            // GMAIL password
    Second general question:
    Reading the codeigniter user guide on create libraries:
    You can also pass parameters stored in a config file. Simply create a config file named identically to the class file name and store it in your application/config/ folder
    Did that, so why do I still need to load the config file?
    I have created a helper file: helpers/send_email_helper.php
    <?php
    function sendEmail($fromEmail, $fromName, $replyTo, $replyToName, $emailTo, $emailToName, $subject, $body, $bodyData)
      $CI->load->library('phpmailer/phpmailer');
      $mail = new PHPMailer();
      $body = $this->load->view($body, $bodyData, TRUE);//file_get_contents($body);
      $body = eregi_replace("[\]",'',$body);
      $mail->IsSMTP();
      $mail->SMTPDebug  = 1;
      $mail->SetFrom($fromEmail, $formName);
      $mail->AddReplyTo($replyTo, $replyToName);
      $mail->Subject = $subject;
      $mail->AltBody = "To view the message, please use an HTML compatible email viewer!";
      $mail->MsgHTML($body);
      $address = $emailToName . ' ' . $emailTo;
      $mail->AddAddress($emailTo, $emailToName);
      return $mail->Send();
    In my conroller I code:
    $this->load->helper('send_email');
    $subject = 'Your free business listing with Phonebook';
    $body = 'phonebook/emails/submit';
    $bodyData = $this->data['ad'];
    $emailFrom = $this->config->item('listingemail', 'email');
    $emailTo = $this->data['ad']->email;
    $emailToName = $this->data['ad']->firstname . ' ' . $this->data['ad']->surname;
    $emailSent = sendEmail($emailFrom, 'Phonebook', $emailFrom, 'Phonebook', $emailTo, $emailToName, $subject, $body, $bodyData);
    Submitting the form I get this error:
    Parse error: syntax error, unexpected T_VARIABLE in C:\sites\thinklocal\application\libraries\phpmailer\phpmailer.php on line 225
    Line 225 in phpmailer.php is:
    public $Host = $CI->config->item('Host');
    Why do I get this error?
    Can someone please help?
