Site Redirecting to Control Panel Home
March 12, 2013 1:07pm
  • #1 / Mar 12, 2013 1:07pm
    Te3d
    This week, I’ve set about upgrading a fairly substantial site from EE 2.1.3 to 2.5.5, including all the required Add-Ons of course (Structure, Matrix, Playa +) After jumping through a hoop or two, I have the backend working smoothly…no errors, each entry editable, etc, Structure seemingly stable.
    BUT when I try to go to the site home page, it redirects to the control panel instead. Has anyone experienced this? I’ve had a blank white page or other issues, but this is the first time I’m ending up on the control panel login screen (or CP home if logged in.)
    Ted
  • #2 / Mar 12, 2013 2:53pm
    Bhashkar Yadav
    Hi Ted,
    This seems strange. As you can easily access the control panel so you can check from General Configuration if site url is correct.
  • #3 / Mar 12, 2013 2:59pm
    Te3d
    Yes…it IS very strange (although I’m hoping for a simple solution.) I’ve checked all the config settings, etc., took out the .htaccess script removing the “index.php” to see if I could get it to work “normally” - but no luck. Putting in the site domain redirects to CP instead of site home page. (CP url works as well, as you’d expect.)
  • #4 / Mar 12, 2013 3:20pm
    Bhashkar Yadav
    Ted,
    Not sure, it may be due to any extension using hook like session_start or session_end and redirecting. Are you facing the same issue if you are accessing any other page by hitting the URL into browser.
  • #5 / Mar 12, 2013 3:30pm
    Te3d
    Yes…I’ve tried putting in direct URLs to pages/templates within template groups…always the admin CP.
  • #6 / Mar 12, 2013 9:11pm
    Bhashkar Yadav
    Ted,
    Can you share your website URL? I would like to see this interesting thing.
    You can PM me.
  • #7 / Mar 13, 2013 5:47pm
    Te3d
    I bit the bullet, started the upgrade over and upgraded the Add-Ons more carefully this time, deleting any unneeded ones. This time, it seems to be working…may never know exactly what was causing the problem.
    I haven’t updated Structure yet. I’m backing the site up first, and if upgrading to the latest Structure later causes the issue, then I’ll know. If it doesn’t cause trouble, then I probably will never know.
    Thanks for posting.
